used red MN
- Location
- Coon Rapids, MN
No harm no foul. Probably should have left my reply at the first sentence, sorry if I wandered off into accusitory land. Did not mean any offense. It was late and I probably should have been sleeping instead of typing. I did wrongly call it an 8N but the neutral start systems on the 9N, 2N & 8N are very similar in operation and only affect the starter circuit and not the ignition.Here are answers:
#2 When I said "no spark," that is what I meant. With a spark tester between the spark plug and the spark plug wire, there was no spark.
#3 This is a 2N, not a 8N. The gear shift must be in the neutral position to start. Even though the gear shift "stick" was moving freely, the tractor was not in neutral.
According to you, "the diagnostic steps should have taken a far different path." It would be interesting to know what you would have done.
Tractor Gal
As an edit to this post, here is the description from the Ford shop manual:
From pages 18-19: Figure F042 on page 18. Quote from page 19 on starter motor and switch:
"Starter switch on 2N, 8N and 9N is provided with an interlock shown in Fig F042 which prevents starting the engine when the tractor is in gear."
This is what prompted me to check the neutral position of the tractor. The interlock is not electrical, only positional.
Have a nice day and enjoy your tractor!
