1940 H. The tractor is one piece again after splitting it to work on the transmission, replace the clutch and rear main seal. Next task is to replace the bull pinion bearings and seals.
The tractor is currently blocked up under the transmission and the wide front is wedged to keep it from tilting. It looks like the axle only has to move out about 4 to clear the bull gear. I'm thinking of using a jack and two roll around hoists to remove the wheel, axle, and housing in one piece.
What do you think ? Recipe for disaster ? Everybody does it like that ? Nobody would ? Any ideas to make it easier would be appreciated.
Greg
Greg
