nh 68 twine route
funny farm
I have an old 68 hayliner. It seems when we first start baling it will miss tying two bales on the right side then were good till we stop or have to slow for say a spot that is a double windrow or large spot. Then it will miss two on the right side again. Also the bales are loose Ive tighttened the tension down till there squished but they still seem loose. Lastweekend right before dusk it worked perfect tyed bales were nice and tight but the dew was just coming in as well it wasnt wet but you could tell the dew was starting on top of all that Im not sure my twine is run ight throught the knotter any suggestions ??
It could be that you need to add a couple more wedges. They are only about 4-5 bucks at your dealer. It could also be that your windrows are to light. If they are light increase your travel speed a gear or two and get some additional hay in there.
The tightness of the twine thorough the knotter probably has nothing to do with your problem but you may want to check and see if the twine tensioner is worn out or the setting is right. If you are getting a good knot its probably fine.
You need to add some resistors to the sides of the bale chamber. These are the "wedges" that the other post was talking about. It was working better when the hay was tough because it was sliding through the chamber harder. I just had a thought. Put the resistors in BEFORE trying anything on the knotters. Sometimes the plunger will cause the twine to yank out of the knotter when there is not enough resistance in the chamber.
As for the missing knots. It sounds like the twine holders are not tight enough. So when a bigger stroke hits the twine it pulls out of the knotter. Also check the twine tensioner. They are the plates that the twine goes through right at the twine box. If they are making the twine pull too hard it will yank it out of the knotters too.
Thanks guys that gives me a good start and know I have a little time to look it all over. This is a great site for good advice.
