NH 855 cylinder issues
facspro
Trying To disassemble a tail gate cylinder. Ive read a few other threads on here but this one doesnt seem to be the same. Ive pulled the oil seal out and there is no snap ring under the oil seal the oil seal sits in a cup and there is a spring clip in between that cup and the cylinder wall body. I have tried to beat the cup assembly down yes I have the setscrew out and the hydraulic fitting out. I cant get them to budge I tried to clean out the groove with a Dremel tool and scraping tools with no luck I can see the two ends of the clip but I cant get it to compress at all or budge. I soaked it overnight in penetrating fluid to try to help break down the rust if thats whats causing the problem and that really hasnt helped I am at a loss as to how to get this spring clip out of here. I really dont want to beat on it anymore for fear of damaging the seal cup anymore than I already have. I am going to attempt to upload some pictures so hopefully they go
If the hole is oval or oblong there is a good chance the snap ring as you call it comes out through the hole by prying one end up and pushing the other end to get it started out. If that is the case it will be a softer wire rather than a harder snap ring type material. You might have to tap the end to get it to start moving. Using a pipe close to the size of your id of the cylinder will help with the damage/deformation of the gland inside.
Unfortunately there is an assembly welded to the shaft end for the safety latch that prevents a pipe from going over it - been trying to envision how to get something to fit around it
As for the ring - the gap is barely 1/8 inch wide and everything I try to tap it with bends or breaks without the ring budging- its soaking in PBBlaster for the night
Another attempt at uploading the pictures
Pull the rod out some cut a pipe in half length ways Clamp it to the rod with aa rag inside to protect the shaft then push the rod in this will push the gland down also. A press could then be used to do the pushing with out further damage to the gland. You might even be able to pin the cylinder to something and put a jack under it and push it in that way to get your snap ring out. you can also use the shaft as the puller to get the gland out at that point too.
Looks like the same type of cylinder as on the 316 baler thrower and the NH dual rake hitch swing. Resealed both of those in the last year.
Drive the gland back off of the locking ring. The ring then comes out. It's still not fun and requires the right combination of picks and screwdrivers, a few choice words, and holding your tongue just right, but it is possible. From there it's pretty simple and straightforward.
Use the pipe trick - thanks caterpillar guy - after clamping the pipe to the rod I was about an inch long for my press so I just turned it upside down and smacked it a couple good times on the concrete floor. Thats what it took!
Still took a little while to get the spring clip out. Once it finally came out didnt take long to get things resealed. Putting the new ring in was a little bit of a challenge but not too bad. Used my piece of pipe and drove the gland down past the groove and with needle nose and a hammer was able to hold the end in place and tap it in working my way around to the other end. Too late to go put the cylinder back on tonight so Ill have to finish tomorrow and get this hay baled.
Got the cylinder back on and back in business. And the tailgate stays up now without slowly creeping down. Thanks everyone.
Now I just need to get the charging issue taken care of on the 4430 but that will be a different thread
