NH baler tires
grandpa Love
NH 315 baler. I was all excited because my new tires came in today, $145 for both tires. I pulled the one side off and took the truck tire off. I just don't see how this skinny little tire is gonna fit that rim?!?!! According to the manual it's the correct tire. Maybe the rim got swapped? Any ideas? Also the fat tire is tubeless skinny and one says tube required...... On a bright note, rim is cleaning up nice!
Old tire
What size is the new floatation tire??? It is mashed together from being stacked. So it could easily be a much wider tire than it currently looks. Also on just about all square balers the left tire is larger than the right tire. This is because the chamber side is much heavier.
JD Seller makes some good points. I had one front tire for a F12 that was all squashed together like that. I put the tube inside and partly blew it up for a couple days to expand the casing. made it a lot easier to deal with putting it together.
6 inches is a wide rim for what appears to be a 6.00 or 6.50 tire, though you neglected to say what size tire you are using
not knowing the exact tire size I would say you either should have a 5 or 5.5 rim
most older implements that use a rim that wide would likely have been equipped with a 9.50 tire
I had a 273 baler that came with flotation tires. I think that was an option. One of them might have been a 7.5L x 15. That might be the reason for the wide rim.
Your wheel is a 6" wide wheel. Measure inside where the tire bead will be. On a 315 baler with floatation tires the left wheel would be a 14" dia wheel, Your baler, having a 15' x
6"wheel,means it came equipt with the standard tires. The 5.50 x 15 tire for the right side confirms that. the proper tire for the left side would be a 7.60 x 15 tire, which would be correct for your 15" x 6" wheel.
Information gotten from NH online parts catalog.
HTH, Dave
OK The tire in this picture looks like a 9.5Lx14 tire this is a wide floatation tire. A seven inch rim would be about correct for that an eight inch rim would be better. It seems you have a 14 and 15 inch rim on this baler. I know that a 5.00 x 15 tire is really narrow and would never have been installed on the chamber side of a NH baler from the factory. The 9.5L x 14 is a very common size for the chamber side of JD and NH balers. I know this because I have a JD disk that uses 9.5 L x 14 tires and I have used the baler tire as a spare for the disk.
Ooops! correction! Standard tire for right is 5.00 X 15 as you have. Also, if you had anything other than the 7.60 X 15 standard tire for the left side, the wheel and tire would be 14", tire could be either 9.5L x 14, or 11L x 14
Dave
And if the wheel in the picture (15" x 6" wheel) came off the right side, a 25 x 7.50-15 floatation tire would be correct! What size is the old left wheel & tire? Or is the dismounted wheel and tire from the left side?
Larryh, haven't looked at build date .... Are you saying price was high? Tires must be expensive around here, these were $40-50 cheaper than anyone else. I get them through a farmer friend.
FWIW.......earlier this summer I replaced both tires on my NH315........just took them to the local tire shop that sells farm stuff and said replace them.
What they came up with was Harvest King tube type ribbed implement tires.........
Left side floatation......11L-14
Right side.......6.7-15
As an aside, when looking at balers to buy, I remember someone mentioning the NH315 had an issue with the Left Side flotation tires......the inner rib would wear faster than the rest....as if it does not mount up true to the axle, but instead cants in at the top. That was the case with my tire, which I believe was original......inside rib was nearly worn through to the cords....outside was hardly worn at all.
Might have gotten by by flipping tire around.......but knowing a short stub could puncture the tire at that nearly bare spot......decided not to risk having to stop the baler to fix a flat, so replaced what might have been a 30 +/- year old tire.
