Since you aren't certain and put those ? at end of your sentences, I recommend you go in motor home and see for yourself if there's hot water and keep a eye on breaker to see if it does or does not trip. If we are playing wag wag here,wag wag there,here a wag,there a wag, I wag water is luke warm and t-stat needs changed, breaker is defective and should be replaced.Well it seems as if in the motor home, there isn't any hot water? The 30 amp breaker trips periodically to the hot water?
Still waiting for some previous questions to be answered. Dual fuel? Make? What is it in?Might have got ahead of myself here? After 2 days of running fine with hot water, now all of a sudden with a new 30 amp breaker installed and new element, the breaker is now starting to trip again???
Your formula is close but incorrect Ohms = volts^2/watts. In other words; ohms equal volts times volts divided by watts.Turn off power, remove element cover, remove wires from the element. Check element resistance and the element to tank resistance. Element to tank resistance should be infinite, the resistance of the element should be related to the wattage. Ohms=Volts/Watts.
Have you measured how many amps its pulling when heating?Might have got ahead of myself here? After 2 days of running fine with hot water, now all of a sudden with a new 30 amp breaker installed and new element, the breaker is now starting to trip again???
Release the hounds!!Maybe a tractor of some sort could haul this thread over to the off topic forum?![]()
AI OverviewIt is a 2001' Fleetwood/ Discovery with an Atwood water heater. Not sure about your dual fuel you mentioned?
Probably does but if shore power is in the spot rent price why buy propaneAI Overview
The water heater on a 2001 Fleetwood Discovery operates on a dual-source system, using LP (propane) gas for quick heating and 120-volt AC electricity (when plugged into shore power or running a generator) as a secondary or concurrent option. The control and ignition circuit for the gas mode runs on 12-volt DC power from the RV's house batteries. [1, 2, 3]
Does yours not have this?
I would like both, but the OP stated no hot water. He also didn't respond to Mark who brought the point up twice. Makes me wonder if something hasn't been altered.Probably does but if shore power is in the spot rent price why buy propane
Me too.I would
Like to know where the tripping 30amp breaker is located
