no luck at all today
Anonymous-0
well it finally quite raining.mowed some hay yesterday and today.just went out to cut some oats down noticed a wet spot on the right rear tire sure enough it was calcium coming out a nice little stream right threw the sidewall on a 165 massey diesel.by the time i pulled into my buddys tire shop two miles away she was flattern a pancake gonna put on two new ones tommorro.the other side is dry rotted pretty bad any way.oh well i will have er back intime to bale saturday so it all worked out.guess it could of blowed out saturday while i was baling and the tire shop was closed.RICK
Sorry for your bad luck, but keep stories like this coming.... Sooner or later you'll inspire me to get the long overdue new tires for my tractor :roll:
Wondering if I should have them filled (fill them myself) if it'd help offset the weight of the baler and tad too heavy drum mower.
Dave
Wher are you located Ric. I noticed in your post the other day that you're in S.E. Ohio too.I had pretty good luck today, mowed all day without any breakdowns.====LOOK OUT tomorrow tho LOL. Keith
I feel your pain. Started mowing with my farmall B & belly mower, darned thing quit. Turned out to have some crud in the gas tank, so I droped the sediment bowl and cleaned that out. The belt came off of the mower next, put that back on. Decided to sharpen the blades as long as I was stopped and the darn little lever on the back of the Craftsman 1/2" drive ratchet broke off, must have used it for a hammersome time I guess. Finally got the yard mowed many hours later. I guess this just helps us appreciate the good days
My Kubota tires are loaded with Rimguard, it's made from beet pulp, won't freeze, and is non corrosive and non toxic - important if you have pets.
