Fuddy Duddy
My 861 runs good. Show around 40 pounds of oil pressure. Burns a little oil. But not much. Starter went out. Ordered a replacement. Got delayed in the mail. That seems pretty common these days. So it been sitting for over a month by the time the starter came in. Went out there to pull the old one. Course you have to remove the oil filter to get it out. I put a little tub under it to catch the oil run out from pulling the filter. But I was surprised. None came out. Once off I put it up side down in the tub as you would to drain it. Not a drop of oil came out. Looking inside the filter you could see it had had some oil in it at one time. Once I got the starter back on I cranked it up without the filter on for just a second. Shot out a good stream of oil. So what's going on?
