no oil pressure
I guess i need to restate the form of no oil pressure, there is no oil circulation, the oil filter is dry, this is a 1310 ford tractor.
What i did fine was the Oring on the oil pump pickup tube was cut. I will replace the Oring and hopeful i will have oil pressure.
Tell me what you thank.
THANKS
I THINK that if the portion of the pump pick-up tube that has the cut o-ring sits above the oil level in the crankcase you my have solved your lack of oil pressure or more to the point, the inability to catch prime..................
