ok I rebuilt my 9N 5 years ago all new everything in motor. Ran great for two years then found that the tsv33 carb had a broken carb float pin holder tried to fix it with jb weld head for 3 years then started flooding out when engine was turn off so i started turning off gas after each use that worked kind of, if I did not turn gas off immediately it would not start back up. So here we are present day snowed heavy over new years went out and started tractor ran fine pulling heavy wet snow most of morning then it started to miss so i pulled it over to the garage to check fuel flow and it was great tried to start it just turn over with no start, that drained the 6 volt battery down cranking it trying to start it ,then i hooked up a jumper cable from my car to the tractor 6 volt battery again just spun the engine with no start.
I then charged the 6 volt and hooked up a spark plug tester to cylinder 4 cranked it over no spark. checked voltage at battery it was 6.5 volts, checked voltage at key 6.5v checked voltage at resistor block it was 5.4v checked at distributor it was 5.1
Went kind of crazed and decided to pull the distributer and points they were warren but looked good should have stopped at resistor but no had to over thing problem.
Just need some help on what to check how to check systematically so in not rebuilding the engine due to some small problem. I have service manual and have run thru the steps but I'm now at a loss of spark (no pun intended).
PS thanks to the members that helped me find a new carb top that problem should go away after I find spark.
