Roy Warren
First post in over a year, but have been reading all the post and archives for about 3 weeks, but still no luck.
1950 8N, 6 volt, side mount. After restoration tractor ran for a month or so, but never good. Ran rough, bogged down when load applied. Finally died.
Tried all the remedies I've read here:
Dell's sparkie test. No spark.
6V+ at points with points open.
6V+ at both coil post.
about 5V at top of coil with points open, 3V closed.
Jumped key switch. Still nothing.
New Battery and cables, New Carb, Drained old gas and replaced. New plug wires, coil, condensor, points
Tried 3 sets of points, rotors and condensors. 2 dist. caps.
Took #1 plug out, found TDC with finger, Rotor lines up with #1 wire. No mark on my flywheel.
Tried rotor pointing just before TDC and just after. Neither worked.
Points set at .015 and Autolite 437s at .025.
No play in dist. shaft.
Cranks okay but will not start.
I don't know what else to try, other than replacing the dist, but I hate to just throw more parts and money at it without knowing.
I would appreciate any help.
Roy
Roy
