Anonymous-0
I could really use a recommendation on an additive
for a 1950's 4 cylinder engine. I understand a
valve job is almost inevitable.
Lead in gasoline was used to "lubricate" the seats. This was especially important with the intake valve which were not hardened to the same specs as the exhaust.(quoted from post at 03:43:22 11/01/09) I could really use a recommendation on an additive
(quoted from post at 00:41:28 11/01/09)(quoted from post at 03:43:22 11/01/09)the intake valve which were not hardened to the same specs as the exhaust.
There never was a problem with the cooler operating intake valve. The earlier exhaust valves and seats were manufactures from softer metals that also had a lower melting temperature.
The fouling left by lead formed a film on the exhaust valve/seat which prevented direct metal to metal contact. Spot welding caused by heat and pressure was thus less prevalent.
