non-toxic hydraulic fluid
John Dority
Does anyone use or know of non-toxic, and biodegradable hydraulic fluid that will work as a replacement for the transmission and hydraulic fluid of my IH 350d utility? (I currently use hydraulic fluid from Tractor Supply company) I like my old tractor, it does everything I ask of it but I don't like the leaks and the potential disaster of a serious spill.
There are several brands of vegetable oil based hydraulic fluids used in food processing plants. Plan on paying 3-4 times what you would for petroleum based fluid.
AMSOIL makes what you are looking for. Used in all kinds of industrial earth moving equipment, where a blown hose can spew many gallons of fluid causing an environmental nightmare.
http://www.amsoil.com/storefront/tbi.aspx
If you order it, give them my dealer number, 344440 so I get the credit for the sale, doesn't cost the customer any thing, but helps me out. I really don't push the products, I am mostly a dealer to simplify purchasing for myself, but sometimes I encounter a co worker who asks me to order something for them.
Charles
Wesson oil is not stabilized and will oxidize quickly. In other words, it will, for lack of a better description, rot away. The film strength is not sufficient and you will start spalling gears and bearings. I would not use it.
Wow! they actually make the stuff for outdside equipment. Hiow long will it last? As long as regular hydro fluid ?
I use lots of Amsoil lubricants, engine oils, gear lubes, auto tranny fluid, greases. They are all top quality and I know have helped me run many more miles than other lubricants would have. The gear oil sold me on the products. I had (still have, doesn't run however) a '88 Jeep Comanche pickup. It has a Pugeot made 5 speed, that is very tight tolerance parts inside, but they specified 90 wt gear oil for it. In cold weather you could not shift it for the first couple of miles. I switched to Amsoil 90 wt and it drove like summer time.
I have a '99 Plymouth Breeze 2.0. I first installed 10W30 Amsoil at 45K when I bought it, it now has 170K and runs perfect, I change oil every 10K and thats too often.
I have a '91 Ford Ranger 2.3L 5 spd. I run Amsoil ATF in the Mazda made 5 speed (ATF is the proper fluid for this) and 10W30 in the engine. Again, I change it every 10K. Got the truck at 18,500 mi, it now has 233,000 on it. Also have 90 wt gear oil in the differential.
I cannot say enough good about the products, they sell themselves if you use them. 2 stroke oil is the best I've ever seen. Gas will keep a year or more, mixed, in the fuel tank.
Charles
Using vegatable is not a joke ! VICKERS, the
largest manufacturer of Hydraulic components in
the world, (now an Eaton Division) has pumps
and valves certified for vegatable base oils,
and HWBF, (high water based fluids, used in
steel mills, foundrys, where a pipe break using
petroleum base products would be an extreme fire
hazard) Cheese plants using hydraulics to lift
400 lb blocks of cheese, use polyethelene glycol,
a safe food grade fluid, if a drip gets on the
cheese block, it is't harmful, but can just be
wiped off. Brewerys use hydraulic motors to stir
the mash, and also use polyethelene glycol fluid.
