Not Pretty, But It Works
Allan in NE
Had originally plumbed the return from the live pump to the fill pipe. That didn't work even a little bit 'cause it pressured up the extension tank.
So, I ran it right back to a "T" at the intake down at the belly. Not legal I know, but that sure cured the ol' sis. :>)
Allan
looks neat - ---- do you have a filter in the line anywhere? i plumbed one into my return line coming out of the valve block.
Question for Allan: What kind and type of camera do you use for these pictures? They are always so sharp/focused, properly exposed, and obviously easy to transfer to the computer. Would appreciate your response! I'm still living with the 35mm film camera- - -.
hey allan is there anything not legal about being a farmer & doing your own rigging things ? we all do it, & we all know its not right, but we also dont have to pay boys in town that "think" they know how to do it better than us back yard boys :)
Alan,
Other than your auxilliary tank on top it now looks exactly like ours that I tried to describe in an earlier post when you started the project. Our friend plumbed it that way, galvanized Tee and all, well over fifty years ago and to say the 1950 M has done a lot of work over the years would be an understatement.
Ours has worked just fine an I anticipate that yours will too.
Regards Don
It should work fine but there are two issues you need to consider.
1. By returning the oil directly to the hydraulic pump you may encounter overheated oil if the the hydraulics are used heavily because you will no longer have the reservoir to help cool the oil.
2. By not returning the oil to the reservoir first, any dirt that enters the system from hydraulic couplers will go directly to the pump rather than having a chance to settle on the bottom of the reservoir. A return line filter would be a easy remedy for this problem.
