Noticed The Guy Down The Road...
Anonymous-0
...who has a small Allis Chalmers, narrow front [don't know if it's a B or a C, never learned how to tell] with a Woods belly mower. Most of the summer it sat out in the yard in the weather, got mowed around when he mowed the lawn, etc., etc. Now that it's winter, the Allis is under the protection of the carport, and it has a recent coat of orange paint on the gas tank.
I guess progress is where you find it.
And I comment ONLY because the owner seems to be a man after my own heart...as I look out the window at my two International pickups waiting for further restorative wrenching.
The way I tell B from C from a distance is the C will have five bolt wheels with standard looking lug nuts. The B will have one large nut right in the center of the hub to hold the wheel on a splined axle shaft. This is the rear wheels. I have seen a C with the high arch B wide front but I'm sure it didn't come from the factory that way. You never know what has been changed over the years. I also seem to remember seeing a B with a single front wheel but it was some kind of vineyard setup, factory or home brew'd I have no idea.
Like the other post said, B is WF, C is NF. CA could be either, but has the hand clutch on the rear axle, most of the time on the right side.
The later B's had the C style rear wheels and could have an adjustable WFE as well. They were narrower than the C however. The distance between the final drive housings on a C is considerably wider than that on a B. There were many, many Cs with the adjustable WFE. Other than looking at the serial numbers, another obvious difference between a C and a B was that the pitman arm off the steering box on a B pointed to the ground and the one on a C pointed to the sky.
Need another International? Dad got one years ago, it is sitting here. Too far gone for me to ever get to, too much good metal for me to smash it....
--->Paul
