Nuther plowing question
BobReeves
Looking at the photos in the plowing thread makes me wonder. Without a roll-over plow do you dead head back to the starting point? The photos are showing the sod turned only one way?
When I plowed my acre I went down one side and then up at about the middle and worked my way to the inside on one side and to the outside on the other. Problem was I ended up with a pretty good ditch in the middle where I changed directions.
How do the experts do it?
We plowed in one time and then out the next. Yes if you are not careful you can get a ditch in the middle. Smaller bottoms and slower speeds keep it to a minimum. The ditch gets filled in the next time
it is plowed. We had 100 foot wide strips alternating so driving on the end was not too much.
You plow what is called
"lands". You start down the
field lowing up one side and
down the other. When that one
gets too wide you love over a
ways and do another. You space
them so when both are as wide
as you like you have that much
left between. Then you plow
out the section between which
leaves a "dead furrow". Then
next time you plow you start
by plowing into the dead
furrow to fill it and reverse
the process. That way the dead
furrow gets filled in and no
permanent ditches are left. In
theory anyway. Lol. Odd shaped
fields make that difficult.
When we plowed fields which was years ago, yes, plowed dirt in one year then plowed dirt out the next year. There was always a 'dead' furrow in the field. You were plowing in 'lands' (strips), there was no way to avoid a dead furrow when you finished the 'land'. From the eastern corn belt perspective we never used a one way plow, they just were never seen at dealer lots. Another eye opener from the plowing thread is plowing without coulters. Plows at dealers here would not have sold without straight coulters to cut residue on the plow. Never saw or used a plow without coulters until they were seen here on YT forums.
Been a while but when I helped FIL with plowing we always plowed that way. With practice you can get the dead furrows filled pretty well with the cultipacker or disking. Always started at the old dead furrows the next year. All the fields were fenced and we used trail plows. Dad didn't like plowing the headlands so I had to wait till the grill almost hit the fence before I turned and tripped the plow. The unplowed ends left enough room to turn with the picker or binder in the fall. I take hay off that field and those three dead furrows are still there. The woodchucks prefer to burrow in them. I miss those days and working with Dad.
That?s one thing I like about the two way plow it sure makes working odd shaped fields easy . I thought I had a picture of me finishing up a small land last fall but I can?t find it
No matter what size plow I had...3x16 up to 6x18...I always plowed about 8-10 rounds in a land...plowing together or plowing apart. Made for a comfortable distance on the headland. And always adjusted for field size and shape. After consolidating fields, mine are all 1/4 to 1/2 mile long. No point rows anymore. But all are chisel plowed for the last 20 years.
I had a brother-in-law who could plow a triangular field starting in the middle and would not go all the way to the end the first rounds and each successive trio to the narrow end would get longer, the last trip around the field would be al the way around . He never did anything but farm row crops and had learned that, My nephew farms far more land but never learned to estimate the size of the field to get it to work out right.
BobReeves,
Back in the 1950's my farther set up, with the USDA help, sets of fields that contained pairs of contour strips.
In one instance there are 8 56 foot wide strips that alternated crops (i.e. Corn hay corn hay corn hay corn hay).
You plowed out one strip throwing the soil up hill and came back the paired up strip throwing the soil down.
The in between strips would stop the soil from eroding on our HEL.
It really looks neat from an airplane.
Keith
An example from my area, not my land.
And if you do it right the dead furrow is hardly noticable when you are done and if you work the ground cross ways for second time over that dead furrow is gone.
Sod is different but my BIL taught me how to plow dead furrows back in when plowing cornstalks and grain stubble. I run the plow very shallow
with the front a bit deeper than the back to fill the furrow back in. We used to grow a lot of white and coloured beans so flat level fields
were a must for proper operation of bean pullers
The garden I plowed was small,so I
just backed up and made the next
pass. Plowed one last spring and
left a big ditch in the middle.
Really hard to disk out.....so
backing up was a simple solution.
We always just didn't plow the last round as deep lessening the depth of the dead furrow. Then with a drag field cultivator or such going corner ways would fill it in pretty well.
