Britcheflee
I am getting to the point of putting nuts back on bottom of con rods - the ones that came off are fine thread and have slots around the top - looks like a castle nut but not quite real thin slots - on one con rod there is a regular nut and what looks like a thin lock nut!
I read that it is recommended to replace these nuts. When I go to auto store they are having a problem with matching the nuts. I have also been told by a couple of older guys that it is ok to replace the old ones - just torque them down.
What to do? If recommended to replace what should I go in and ask for exactly?
Re Rust: Weather is closing in, I have tractor tarped but even so moisture from air caused some light surface rust on exposed engine parts last time it rained - this isnt going to affect anything is it? Going out now to give everything a spray down with wd40 to try to keep this at a minimum.
So far I have two pistons in the new sleeves!!!
Lee
Lee
