Lou from Wi.
Well we went down to get the O.C.46 crawler today and man -o-live was it cold. Got it started, enging turned over fine,NOT STUCK thank goodness. Plate reads MODEL# 11-3104 O.C 46 CS series E Serial# 801 816 234. Started then died. Backfired several times BUT IDLED FINE,(before it died) Cleaned plugs sanded points & rotor ,changed condenser found 2 plug wires No continunity on both, Put on new ends and re checked. O.K.now But still no spark through the plugs. Got spark to points. Distributor has coating of surface rust(very little)Will clean for now then re seal plate when we get it home. Ordered new coil, points, rotor button ,Plugs and new wire wire.
The ignition system was changed to 12 volt with a resistor at the coil. No indication (what is visable with out taking coil bracket loose) as to what brand.Hope you know what to get at the parts store shows coil to be a DIAMOND LB 88. Sure could use the help with resistor brand. Engine is sound with no knocks, grinding etc, Sounds good so far. Was real surprised that the crawler fuel system has an electric pump .Has Hyd leak somewhere in the system at the rear hoses. probably old and weak,Will change em too. Seems o.k so far. Did we miss anything in the non starting endeavors?Before we started it, we put a capfull of oil in the cylinders thru the plug holes.Just not getting spark to the plugs.We are going to change the plugs to Autolite #86 with .025 gap, for good measure. Got the re-cored radiator on .NO LEAKS. Gonna do it RIGHT,but need help. Thanks for reading and responding.
LOU & VICTOR ps. Ordered parts manual today.
