O/T: computer BIOS question
Anonymous-0
A friend of mine brought his pc to me, said it won't turn on. I asked what he was doing last. His answer: changing settings in the BIOS. Oh joy. It turns on, but nothing shows on screen. No beeps either. How can I access BIOS? It's a home-built system; video is not on-board. OS is Windows XP.
Opinions and suggestions are appreciated.
Thanks,
Anthony
You need to get the manual for his motherboard. If he doesn't have it, try to find the manufacturer's name and the model number of the motherboard; most manufacturers post the manuals online. The manual will tell you how to get to the BIOS.
HOWEVER, the absence of a beep code means that it's not even going into Power On Self Test. So it may have nothing to do with the BIOS.
If he was resetting the bios by switching a jumper on the mainboard, he may not have set it back to the "normal" operation setting. That can keep it from being able to start. Like was already stated, you need the manual to know what jumper to look for and how it is supposed to be set. Hope this helps.
Ron
Many diferent ways. Try control-alt-delete as it boots. With nothing on the screen, do you mean nothing or blank screen that lights up? Remember to try F8 if he messed up the video setting.
Boy did I blow that. I meant to hold down the delete key when booting. Works on many computers. Bad fingers,bad,bad--
Different M/B have different method of accessing the BIOS. The latest favorite seems to be F2 but have seen Insert and Delete used. Either way you hold the button during the POST (power on self test) and there you go. If you are not getting any video i would pull and reseat the card. While you are at it pull and reseat everything on the motherboard you can. Memory, Peripherial cards, power connections, HDD connections, etc.
It's interesting that he says he was "changing the settings in the BIOS", but didn't tell you how he got into the BIOS settings in the first place. Maybe you should call him back and ask him what he was REALLY doing. Why was he changing the settings in the first place? His problems may have nothing to do with the BIOS settings.
If it was BIOS settings, chances are he was playing around with the overclock settings most motherboards have today. This would explain why he can't get back in to fix the settings. Motherboards that support overclocking usually have some way to reset the BIOS settings back to some sane value. Find the manual and it will tell you how.
