O/T Dry Cracked Hands
John B.
This is unbelievable but I found a way to cure my cracked fingers and hands during the winter months. I noticed that they would start cracking 15-20 minutes after I would get a chill down the back of my neck and back. So I started wearing turtle neck T-shirts with long sleeves, hooded sweatshirts. This keeps the cold air off my head and neck. I also put a towel around my neck when I walk out of the shower. I know everyone is going to think I'm nuts but I've been doing this since 1996 and thought this is a great place to share it with everyone. I started by being aware of when I got chilled and took action. I haven't used lotion on my hands since then. It works for me!! Hope this will help some one else out there.
Thanks for the tip. Your right, sounds a little out there. The more I wear gloves the better my hands. Deer skin gloves with lotion on my hands helps.
Interesting theory, can"t argue with success. My best remedy, especially after the fact, is Neo-sporin + (jelly base, not the cream). Those stupid little cracks can hurt like hell, and they always occur right on the working surfaces of your hands, get in the way of everything you do. The Neo stuff with the topical aneshetic included makes "em feel better right now, and the petroleum jelly base works in advance to prevent the cracks.
glad you found something that works for you...doesnt get super cold here in s Tx but my hands dry out and crack too...been using Corn Huskers lotion for more years than i care to remember and it works as long as i put it on first thing in the morning.
Well, I suppose if it works,,,, My hands used to be in water all the time in the work that I used to do. I used Corn Huskers Lotion.
1. Anytime your hands are wet, dry them very well, even between the base of the fingers. If the hand towel is damp enough to notice, get another one out.
2. Check you humidity level in the house, ESPECIALLY if you have a wood stove. Within a day of arriving back home in Nebraska, my hand start bleeding b/c the humidifier wasn't turned on. As soon as the humidity gets back up, they are fine the rest of the holidays.
When I was a child the corn huskers worked ok, but we started using plain ol lard, and it worked better on the dairy farm. We also replaced the bag balm for cow udders with lard, manure would not stick to them as bad either.
That being said, a friend of mine that is a mason says the best they have found on their crew is once it cracks open, use super glue to glue it back together. He claims it is heaven sent.
I mean no disrespect at all, but I'm not so sure the neck, and hands thing are related, but nothing is imposible, I would almost bet their are other factors overlooked.
IOWA NORTHEAST,
When they crack open they sure do hurt. I have been using the super glue for years now to hold the cracks together and then the pain goes away. Since I have retired my hands have become a little more pansy at times and they don't crack as much.
Neosporin is great stuff; I believe it does help wounds heal noticebly faster.
However, for those annoying little cracks on the fingers that hurt like h311, I find that applying super-glue directly to them to be the best medicine. It seals the cracks right up, stops the pain immediately and they will heal under the glue.
Works for me!
Mine finally quit cracking when I started using Eucerin Intensive Repair. I buy it at Rite Aid and its not cheap. Cost about 13 bucks for a 16.9 Oz bottle. It works for me. I would use neosporne on the cracks with a band aid over it when they did crack open.
Whatever works.
It is painful.
I've never tried it, but I heard one old cure was to actually pee on your hands on a daily basis. Could just be an old tale, but maybe it works.
Anyway, whatever works.
I used that udder balm when I was outdoor work alot.
I dunno how far their distribution reaches, but here on the west coast, there is a product called "Working Hands Cream". Can't be beat. Daughter of a dairy farmer developed it because her dad's hands were always split and bleeding.
Ben
I was a city letter carrier for about 15 years and generally worked without gloves in order to handle the mail bundles easier, i.e. sorting between fingers, etc.
I used super glue until I learned of New Skin, a liquid bandage. Stings for only a short while.
St. Ives, Swiss Formula hand lotion worked better for me than others. Less sting upon applying to cracked and bleeding fingers, and less of a greasy or sticky feeling compared to others.
Many say if your hands and/or feet are cracking you are not drinking enough water each day. Not sure that I agree with that at all.
I went to TSC last night after hearing an add on the radio yesterday about a very good hand product. It's called "Outdoor Hands" and I got me a tube of it to try, its sorta pricey at $10.00 a tube, just started using it last night, maybe somebody else has used it and can report on whether it works or not.
Since lotions are used mostly by women, the mftrs add a nice "scent". Its the scent that causes the sting when lotion is applied to a cut or cracked place.
In addition to what's been recommended here, I would try a good facial moisturizer like Lubriderm or Cetaphil. They are designed to moisturize. They don't have artificial scents added and the skin will absorb them really fast.
I also have trouble with the skin on my toes cracking in Winter. What works best for me is to rub Vaseline into my feet and toes with my hands, which helps the hands at the same time. I have done that for years. It makes it a little hard to put socks on right afterwards though.
John,
I have year-round eczema. It has gotten so bad of late that my dermatologist put me on prednisone for 15 days.
Here are two creams that he recommends:
1. Eucerin Plus.
2. Cera Ve moisturizing cream by Coria Laboratories.
Good luck,
Tom
I am a diabetic, just before I was diagnosed as a type 2 diabetic I would drink massive quantities of water every day. I didn't link the two together but my hands were softer then than now. When I got my sugar level where it should be I don't drink near the water as before so there probably is some truth to that. Now I use Carmex, the salve for cold sores. It softens things up pretty good. Steven
