O/T Echo Chainsaw
Anonymous-0
I Have a Echo 550 chainsaw And it started missing, changed plug, still missed, now lost all spark to plug. any help please. thanks
It seems you have eliminated fuel as a problem & proven the problem to be fire. Now its either points & condensator or coil (if an older saw) or ignition module (if modern). A blocked muffler will act the same way. Take the muffler off & try to run it. If it still won't run, its the points/cond. or coil, or ignition module.
It's Electronic, i have checked muffler, but lost spark, did not know if it could be coil or ignition module. thanks for your help
Check to make sure you don't have a frayed wire from the kill switch. Seen it a hundred times. Check the switch too.
