o/t how much concrete do i need?
i know someone on this site will know the answer to this.
i want to build a shed to house machinery and hay it is 35 ft wide 54 ft long. the footing is 18 in. wide x 16 in deep. 10 in x 3 in channel done the middle of footing.
how yards of concrete will i need?
(quoted from post at 23:33:02 09/02/10) i know someone on this site will know the answer to this.
If you are asking how much for the footings I came up with just under 12 yards.
Gotta convert everything to the same units:
3 inches = .25 ft
10 inches = .83 ft
16 inches = 1.33 ft
18 inches = 1.5 ft
OK, you have the following:
2 side footings:
2 x ((1.5 x 1.33 x 54) - (.83 x .25 x 54)) = 2 x (108 - 11) = 2 x 97 = 194 cubic feet
2 end footings:
Subtract the thickness of the sides from the length of the ends, so 35 - 3 = 32 feet.
2 x ((1.5 x 1.33 x 32) - (.83 x .25 x 32)) = 2 x (64 - 7) = 2 x 57 = 114 cubic feet
Total:
194 + 114 = 308 cubic feet
308 / 27 = 11.4 cubic yards
12 yards should do it.
exactly 38 yards assuming the pad is 4" thick, I'd order 40 yards to make sure you have enough. If you depths are right on you'll be fine , but if your off a couple inches here and there you will need more than 2 yards extra. Hope this helps Mike
I came up with 38 cu-yds too. Give these dimensions to your concrete supplier and he will tell you how much to order. You don't want to be short. Hal
Just for the footer,13.19 or like someone else said 12.give or take on how accurate your footer is.or 35 more for a 6"floor(48Y.) or 23.4 for a 4"floor(37Y)
