O/T JEEP Laredo
Anonymous-0
got some bad gas in the Jeep ,, Tried STP , WYNNS , LUCAS , ATF , And High Test Gas ,Most the time it runs O>K,, HoweverIt simply is not getting enuf Gas To Get Down and RUN OUT .. Afraid I will have to drop tank And Perhaps by a new Pump $124 .. Jim
You said it's not getting enough gas. Do you blow out the line? What exactly do you mean by 'bad gas'? It was just old? Had water in it? Had other debris in it? Tried a new fuel filter? Or at least a temporary bypass of the fuel filter with a piece of gas line to see if it runs any different?
As far as fuel system cleaner, my personal favorite is Berryman's B12 Chemtool. Run it down to 1/4 or 1/8 of a tank of gas, pour a couple cans of B12 in and run it. Lots of folks only add their fuel system cleaner to a full tank of fuel, which gives you a more diluted mix.
Good luck with it!
Anthony
