O/T Mobile home electric problems, found it
old
Well after pulling off one panel of siding I found which way the wire went. I then pulled off some under pinning and laid down under it( not what I call fun) and saw a place in the wire that has a burned area in it. Hope that is the only bad spot. Bad thing is I also found where the kitchen drain pipe has been knocked down by the insulation I had put in in May of 2007 by a contractor poor work man-ship. So now what was one problem is 3 oh well such is life. If I can I will put that wire in some pipe at least in the area of the splice it will have in it.
Thanks guys for your ideas they did help
I would if there was some place to mount a box but this wire hangs out in thin air and I do not have an air hook for it. When I splice things like that I use a 6 inch rule as in all wires are 6 inches from each other at the splice and then taped real well
Should use two boxes with a piece in between, maybe you can find a spot to mount boxes that way,you will meet code that way!!
Agree with teletech below about adding boxes if necessary for your repair. Could give you a place to add a receptacle in a more convenient spot, who knows. A buried splice is really asking for trouble no matter how carefully you do it. No wonder recent codes require AFCI breakers almost everywhere.
Kirk
It is not a buried splice it is a splice that sits between the floor joist and the iron frame and is a good 3 foot off the ground but in an area that there is nothing that will hold a box and I sure do not want a box sitting in mid air being held up by the wires
Substitute inaccessible for buried, I knew it was not underground. Still a real bad idea. Have a hard time thinking you can't come up with a way to make the repair and have it be right. As said before, cut the circuit short somewhere convenient, mount a box, make a splice, run new to another convenient location, make another splice to complete the circuit.
Good Luck whatever you end up with,
Kirk
Only going to say it once..
Mobile homes and bad wiring are not a good thing,..Would seriously consider rewiring the hole thing.....
