O/T Wood value
I have several black walnut trees that I am going to cut down to open up some more space around here. They are 10+ inches in diameter and straight trees. Any idea of a value for them. I am going to try to sell them.
Before you get them cut, have them sold.
Also, if they are yard trees a mill might not want them due to the chance of hardware embedded inside the tree from years gone by.
Christopher
Call a place that buys standing timber. What state are you in? There is a place in Michigan north of Lansing that buys standing timber called Maeder wood products.
Dont cut the trees down and then ask a mill to buy it. I am told that when a tree is dropped by lumberjacks the grain is stretched and thereby ruined. I guess the way to drop the tree is to cut out 4 wedges and then have a small portion in the middle to break. (I dont know if this is true)
Of course any agreement that you sign up to should include the company cleanin up the mess they make.
I'm not familiar with walnut, and I haven't been following the prices on high grade hardwood lately, so I don't know what they're worth.
What I would suggest is that you contact someone familiar with cutting high grade HARDWOOD saw logs. At 10" I do know that they are on the small end of what would normally go for veneer logs. Length, diameter, sweep and defects are all critical to the grade you achieve with veneer, and to some degree, sawlogs. I've seen prices running anywhere between 100 and 2000 dollars per thousand feet on some of the veneer we've sold in the past.... so you can appreciate that one wrong cut can cost you a lot of money.
Again, contact someone in your area who's in that business. They can price the stuff for you, and if they're hungry for wood they'll probably come out and help you cut them to length, grade them on the spot, pay you and take them away. If they're not hungry for wood, hey won't return your phone call or won't come out at all. Then you have firewood....
Rod
I agree with everyone's comments. I am thinning a lot of walnut from my wood lot. Some good sized stuff too. All is going for fire wood. Most mills want trees in the 18 24" class, depending on species and uses, and straight with few limbs. You might contact a forester and have him give you some advice. In a few more years they may be worth more than what you plan to plant.
Larry in Michigan
That size is the bare minimum for logs. How much do they taper? A log is figured on the small end. Anything under 6 inches is not a log. They may be worth more in a few years than what you will get from planting something else. I would let them grow.
You've got to check your local market. Around here in central NY, those 10" trees would be worth just about nothing.
Interesting though - that small hard maples are now bringing a premium - seems there's a big demand for hard, pure white wood and the young trees are often the cleanest. A few years back - they were worth nothing at the mill.
Man, I have heard some good ones, but stretching the grain is off the charts ludicrous. That makes the board stretcher we used to talk about seem almost possible. Gotta go, I'm looking for my left handed monkey wrench to stir some striped paint with.
------------------- High Low Avg. Last Qtr. Last Yr. Volume # of Rpts.
(All prices shown as $ per MBF, International Scale)
Walnut, Black $2,500 $835 $1,520 $2,610 $1,990 17 Int. - MBF 9
Still want to make firewood out of them.
Walt
Good luck on finding a left handed monkey wrench.
They're really hard to come by.
I've been looking all day for my metric adjustable wrench.
Any ideas on a 50-100 year old barn made of black walnut. the actual barn board siding appears to be something else. Inside there is a 50x100' loft, mostly black walnut and a lot of 4x6" support beams. The loft is pretty close to 3/4".
Okay so Im wrong. A guy that used to have a tree removal comp. told me that I had no evidence to counteract his comment.
Keep in mind that this wood will still have to be milled into lumber, and kiln dried down to 6-8 Moisture Content. This leaves some work left to be done which will affect your log price.
You can cut some 6 inch boards from 8 in small end logs.I can get plenty of clapboards from 8 in white cedar.Band mill will do it easy.
I am posting this at the top of the thread for visibility. Responding to the post below, I shot off my keyboard(same as shooting off ones mouth, only different). I called a friend who has been in the business of producing walnut logs and lumber for about 35 years and ask him about "stretching grain". He said(as I thought) that grain does not stretch, however, what does happen when a tree is felled improperly, long splinters are pulled from the log, destroying its veneer quality. My comments below were not meant for Mr. guru, but for whoever gave him the misinformation.
On another note. Mr guru, do you have any idea where I can obtain a hammer spring for a model 90 Winchester?
