OC46 fuel supply
Polkwing
Check Oliver Cletrac discussion form for detailed info on fuel suppy from tank to carb. OC46 won't start, runs only briefly with starting fluid and kicks in for only a couple of seconds. Thanks for advice.
Polkwing
OC46 3 cyl gas
Yes, I get gas through the entire fuel line up to the carb..thru in-line filter, elec fuel pump, fuel flow regulator (?) ( looks like a big silver dollar with movable inner dial..don't really know what it is), clear up to carb.
Removed fuel line at those various locations to be sure gas was coming through.
Engine fires for a few seconds on Start fluid then quits??
Polkwing
Have you taken the carb. apart? What kind of needle and seat does it have. If you take the needle out will gas run out?
Called off the search for the weekend. I suspect the carb is the problem but need to remove hood, muffler, and get loader arms up and out of the way to check the carb.
Thot about checking gas tank outlet but removing tank is major undertaking, counter-weight rules out that possibility.
How would I go about breaking into fuel line from tank, using into low air pressure back into the tank to see if something was obstructing tank outlet? Cannot see tank outlet by using light at tank filler throat. Or other way around, introduce air pressure at filler throat and see if gas goes thru?
Am willing to try anything but removing carb etc will take time and patience.
Thanks for your reply. You helped me several years ago with a problem on an OC3, since sold.
POlkwing
