gears
Anyone out there know what the fuel sender and temp sender should read? I can't find the range anywhere. Neither "new" gauges read anything. 7 yr old replacement gauge cluster - from unknown origin, Tach & hour meter worked so I never worried about it.
Before putting the loader back on I figured I would fix some of the details.
Bench test can get the fuel gauge to work but no joy on the temp sender. Dug the old cluster (with 3697 hours and a broken/stuck pointer) out and both gauges work (on the bench) - going to swap the old temp assembly into the replacement cluster but would like to test the senders / wiring on the tractor too.
