Oil Analysis Test
I get the kits from Napa, 13.00 and change plus postage to send it to the lab. Runs about 2.00 to ship. Results usually come back in 10-14 days. Southern States Co-op, your local Caterpillar dealer, and others also can do it. Napa was the most convenient for me and price competitive since our local Southern States closed.
Back when I was a Reliability Engineer for Michelin, I had all of our lubricants checked through Polaris Labs (www.polarislabs.com). It used to be around $13 a test, but it has been a while. That included test bottles and a very detailed report.
Just a little advice on your sample. The majority of foreign matter found in the samples is a direct result of bad sampling practices. Be extremely careful on how clean the surfaces are around where you will be taking your sample. Also be careful with the lid of the sample bottle, as it will pick up foreign matter very easily.
Good Luck
Scott
They can check for (in parts per million)
Water in fuel soot and sulfur contamination
bearing metals antifreeze contamination
oil viscosity Total base # (oil acidity)
It was a good enough test that the Cat dealer would bring in samples to be tested when I worked there
The only info they need is year, make, and model of engine. What type and grade of oil used, and amount of hours (or miles)
Our CNH dealer has test kits available, maybe true nationwide??
So far, I have used the CAT test labs to do the analysis of samples I have sent them. They have been real helpful about interpreting the results, with my phone call to the lab manager.
It is probably of most benefit to you to go with the company that made your machine. The test data need to be compared to similar engines to be most valuable, and the respective company/dealer has the best data bank for what you are testing.
Even more valuable is the test data from the exact same engine taken at 6 month or 1 yr intervals, depending on number of hours of use. The Cat sampling data should include total hours on the engine and number of hours since last oil change and brand/viscosity of oil. You will want to get a "baseline" sample from each engine to keep in your records.
Paul in MN
Yea, that was a big selling point for them, and there were a lot of surrounding companies that would come and get their samples tested
