oil bath air filter
Anonymous-0
i have owned a 445long since 2006 and wonderingif it is about time to service thr air filter..probably run about 50hours a year,mostly hoggin....not sure when it was serviced before i got it.changed fuel filters twice now....how do you service it.? thanks tuff and stupid here.
pull the bottom bowl off..(usually a clamp holds it on) wash it clean, dry it, and fill back to the full-line with the exact type of oil you run in the engine. hd 15w-40 diesel oil hopefully.
yea, rotella 15-40 bought at advance was lots cheaper at tractor supply.........i think i will have to remove thr grill,battery to get to it.
Unless the 445 filter layout is a lot different that a 610, the air intake is there under the front grill also and it can get clogged and reduce air flow.
KEH
Right, and permanently plug the gauze filter above it..
Clean it per the Manual, or have to clean it up the Hard way..
My Dad and I took a couple of them apart unrolled the screen washed it rolled it back up and put it back together, and it was not an easy job. I think they were both on combines.
