Sparks
Got my 8n running really well with a new wiring harness. So I'm
on to the next project.
This old tractor sure burns oil. Big blue clouds at full throttle
and a some blowby smoke out the oil filler when she bogs down
in the tall grass with the mower.
I mowed for about 4 hours and had to add 2 quarts of oil. Power
seems good but this is my first tractor so I don't really know.
When I was changing the plugs there was an amazing amount of
oil on the #3 plug. Much more than on the other plugs.
Oil pressure isn't the greatest either. Starts at about 20-30 and
goes down from there to about 10.
So I have a couple questions.
How low is too low oil pressure? I don't want to do any damage
What causes low oil pressure in an older worn out tractor?
What can I do about the smoking, short of a full rebuild. Rings
alone? Is it worth doing just rings. I'm not a super mechanic but
I'd pull head off and try it!
Is it worth it to cure the smoking problem? Will it give me better
compression and more power or is it a temporary fix.
Thanks guys. Maybe you can point me to some resources for
these basic concepts.
Sparks.........FIRST THING to do BEFORE you remove yer head, do the dreaded COMPRESSION test. 90-psi min. (dry) then squirt about 1-oz of regular engine oil down the sparkie hole and cranker again fer 5-puffs. RECORD ALL compression numbers.
Most likely, you have sticky rings in cylinder #3. I like MMO (marvel mystery oil), others like ATF. Squirt a couple of oz of oil down the sparkie hole every day for 3-days and do another compression test. Isn't that so much better than tearing yer cylinder head OFF???
As fer engine oil pressure, in 1939 Ford recommended 40wt in HOT CLIMATE. Loosing oil pressure when heated is normal. Its called "viscosity factor". Many try 10-30wt oil which is thin 10wt oil with temperature sensitivity additives. I don't like 10-30, but I run 20-50wt.
As to oil pressure, many N-tractors run about 10-psi after warm-up. Oil pressure is a factor of oil weight (10wt, 40wt, etc) bearing clearances; oil temperature; oil pump wear. The oil is spring loaded pressure limited to about 35-psi. ......HTH, Dell
I'll see if I can scrounge up a compression tester. Sounds like an interesting investigation.
What exactly is a stuck ring? My understanding (limited) is that the rings seal the pistons to the cylinders. The rings don't really move do they? Do they compress and stick in a smaller diameter and cause problems?
I'd be willing to try the mystery oil. If I have a sticky ring and it could be unstuck to solve the problem that would be great. Worth a try anyway.
ATF will work as good and will cost you half or less then the MMO does. As for a way to slow down the oil burn problem at least this time of year is use a straight weight oil like 50W in the summer or 40W or 30W depending on your weather. If hot out the thicker stuff will slow down burning a tad bit.
See if one of those 'no foul' plug adaptors help on that cylinder - I have two which oil up and these at least prolong the run time before having to change out the plugs - eventually they do oil up but at least I can get some work done before having to pull the plugs and clean them.
Lee
Old,AFT dosent have the solvents that MMO contains.I would try a pint of MMO in the Crank case.Ive seen it work on a tractor that was a bad oil pumper.Smoke stopped and oil stopped seeping out of the spark plug threads.Oil consumption will have to be watched closley.
Great! I have a plan now.
But can you explain the stuck ring issue? What about the ring is sticking and how does that cause the smoking?
Can you break it down to basics so I can understand?
thanks
The rings sit in a groove around the piston and they are not attached to the piston in any way - if the engine is left for any length of time the rings bind into the groove and when you run the engine instead of pushing out against the walls of the cylinder they remain stuck in the groove - this causes loss of compression (as the air/gas) can squeeze by, as well as oil being able to come up from the sump into the chamber and get burnt along with the fuel mixture - this is one theory, the other is that the walls of the cylinder are scored/damaged/worn and even if the rings are moving they cannot make a good seal so the same thing happens.
Mine smoked like mad at first but gradually it has improved - you may ridicule all you wish but I bunged in a can of that 'engine restore' last time and (might be wishfull thinking) there does seem to be a small improvement.
Lee
I think you should start a club/website for cheap people....I would be your first signed up member.....I am so bad that the kids call me 'Hobo Dad' because I stop and pick stuff up by the side of the road....much to their great embarrasment!!!!! :twisted:
Lee
(quoted from post at 16:17:48 08/17/10) Well you believe what you want I have never had MMO work for me but have many many times had ATF work so I'll stick with the ATF plus I'm cheap.
I am cheap too. I also have a smoking 8N. So which type ATF are we talking here or does it matter?
