Got my 8n running really well with a new wiring harness. So I'm
on to the next project.
This old tractor sure burns oil. Big blue clouds at full throttle
and a some blowby smoke out the oil filler when she bogs down
in the tall grass with the mower.
I mowed for about 4 hours and had to add 2 quarts of oil. Power
seems good but this is my first tractor so I don't really know.
When I was changing the plugs there was an amazing amount of
oil on the #3 plug. Much more than on the other plugs.
Oil pressure isn't the greatest either. Starts at about 20-30 and
goes down from there to about 10.
So I have a couple questions.
How low is too low oil pressure? I don't want to do any damage
What causes low oil pressure in an older worn out tractor?
What can I do about the smoking, short of a full rebuild. Rings
alone? Is it worth doing just rings. I'm not a super mechanic but
I'd pull head off and try it!
Is it worth it to cure the smoking problem? Will it give me better
compression and more power or is it a temporary fix.
Thanks guys. Maybe you can point me to some resources for
these basic concepts.
