Oil leak fix?
Trent H
My 245 got a bad oil leak out of the weep hole that is under the tach. Anything special I need to know on this fix. My tractor is way out in the woods and I would like to be able to fix it without having to bring it in!
Many thanks ! All the people on this site have helped me many times!!
Trent H
A weep hole under the tach? Could it be the oil line for a mechanical oil pressure gauge? A power steering leak? We need a little more information to give an idea what it could be.
If you're talking about the bottom of the clutch housing, It's a bigger job to fix. Most likely a rear engine seal but could be a trans. input seal. Tractor has to be split to fix. Dave
Hey Dave, From what I have been able to find on this ..... It is a small weep hole just under where the tach cable screws in the block. I was told I would have to replace a seal and gasket under the plate the tach screws into. If I understand right the seal is what the tach goes through. I was just trying to figure out if I could do it without having to bring it home!!
Thanks,
Trent H
Yes you can remove the 4 screws that attach the plate then you can replace the seal and the cork gasket. Your local Massey dealer or this sight will have them. You might have to clean the plate and the surface of the head with a wire bush and some solvent if they wwere permatext before other than that it's a simple job.
