dbrannon-HT
I have read and read but can't find the answer I am looking for. I have a Yanmar 2000D with loader. I am chasing an oil pressure "light" problem. Started with a flickering light that changed to steady bright when RPMs were increased. Shut engine off immediately. Changed the oil (15-40) and filter (Hoye). Restarted the engine and light stayed off for about 15 minutes of light usage then flickering light came back on. This time the light went off with increased RPMs and came on at low idle. Shut the engine off again. Engine is running strong with no noise or oil leaks. I ordered 2 of the brass fittings from Hoye and purchased an oil pressure gauge so I can see what is happening with pressure (not installed yet). I want to keep the annunciator light and pressure gauge. If I use the new fitting from Hoye and install a T, the OLD pressure switch will not match the new threads. (QUESTION 1) What kind/type of pressure switch do I need to install into the NPT threads to connect to the light? Obviously, if I change from metric to NPT threads the Yanmar pressure switch will not match the NPT threads. (QUESTION 2) It looks like I will need to remove the brace that supports the loader that runs directly under the sump plate. I am curious as to whether the screen on the oil pickup may be getting restricted. Do I need to support the loader if I need to remove this support? I am going to go ahead and order the pressure relief valve to have on hand in case it may be the culprit. Any advice would be appreciated.
