Oil Pressure
Anonymous-0
I have a 1953 SuperC and I was wondering if somebody could tell me what the usual oil pressure would be for it at idle. I appreciate your response. Thank you in advance
you should have at least 10lbs or so at a hot idle. If you have less then say 6lbs or so then you have a problem. A rule of thumb many guys go by here is every 1000rpms = 10psi of oil pressure. How many psi do you have when it is hot and wide open ?
Andrew
Way over 30. It is a new oil gauge and I have a feeling it is bad. I put in a new filter and everything was put back together right. I think I am going to try another gauge. Thanks for your quick response.
So you have over 30psi when it is at idel? Your more then fine. My Super C's will hold over 30lbs when hot. Nothing to worrie about unless your numbers are BELOW 5 or so psi at a dead idle. Sounds like you have a nice tight engine.
Andrew
You may need to take a look at your oil pump the gasket No3 may blown or No2 the cover may be warped. Check the pickup up tube to make sure its not sludge up over the opening. You will need to pull the pan. Hal
Way back in the early 80s, my dad got an H for basically free that needed an overhaul. I completely tore the engine apart and whatever machine services that were needed, including turning of the crank and resizing of the rods was done at a machine shop.
I got it all home, assembled it with all new bearings and at that time found out (via plastigage) that the reciprocating assembly had very little clearance. I warned my dad about it, but since the assembly turned over he said to not worry about it. (He was probably just too tight to do anything about it)
We started it up and the oil gauge pegged. Hooking it up to a different gauge showed it to be about 80 psi at idle. My dad (who had high school mechanics back in the 30s) said to leave it and we were going to work it. It was about a year of hard use that the gauge would finally drop down to about 60 psi at idle.
My brother still uses that tractor for buzzing wood and it still has high oil pressure. After a few thousand hours of hard use and troublefree service, I'm not going to touch it.
