Engine or rear end or bull gear pans. Engine I use 30W oil. The transmission/hyds I use UTF and the bull gear pans I use 85W-140 If i remember right it takes 5 qts for the engine. By the way using the wrong oil filter will cause you major problems. I use Wix 57011
(quoted from post at 22:54:15 09/05/12) Engine or rear end or bull gear pans. Engine I use 30W oil. The transmission/hyds I use UTF and the bull gear pans I use 85W-140 If i remember right it takes 5 qts for the engine. By the way using the wrong oil filter will cause you major problems. I use Wix 57011
Thanks Old - Im changing everything this weekend. The tractor has been sitting for a year & I fell the need to service it. Everything is full & looks good but for piece of mind im changing everything. It has a allis chalmers oil filter on it. I don't know who makes them for AC.
The big thing is with the oil filters on the A/C tractors the wrong filter will cause it to have low or no oil pressure and of course no oil pressure can in turn mean a blown engine
