Okay You Guys
Allan in NE
I finally broke down and decided to service my big tractor since it has to work so darned hard in the summer.
Geeze! It costs a lot of money to do that anymore! :>(
Should be good fer another 4 or 5 years now, right? :>)
Allan
It's old, but it sure is a hefty "brute".
I've got the old sister turned up as far as I dare go and it'll just yank like a D8 Cat.
Noisier than bloody he!! tho. :>(
Allan
Look at the bright side... I bet is cost only a fraction as much as your neighbour with that big fancy green one!
I bet for as many hours as you put on it she probably should be good for 5 years too....
I change engine oil every hundred hours on the one I whip the hardest but hydraulics and the rest of it go 500-1000 hours.
Rod
Just be careful going back in the other direction. Looks like you could drive right off the edge. Bill(Wis)- Non-dues paying member of "The Flat Earth Society".
I yanked the air filters out of 'er last night. Derned nert broke my back trying to lift those filthy things.
Probably why the air filter indicator was flashin' at me? :>(
Allan
There you go, disking up all that good stubble mulch. Told myself to not bug you any more about dryland farming cause your soil does not blow like mine, but I couldn't resist the dig.
Not supposed to get over 50 degrees here today,,mixed with snow.
KennyP
You are definitely right, it costs a lot of money to look after "stuff". Just recently put over $ 600 worth of hydraulic/trans oil in an 8100 JD. After all that, only the first pail taken out had anything wrong with it. I do however have some "good slightly used" hydraulic oil which some of my vintage "stuff" wiil get.
I clean air filters ONE time then replace them. A plugged filter or one that is blown out too many times, make for more fuel and shorted engine life.
Just changed a neighbors air filters in his tillage tractor. He raised cane with me for "wasting" $100. He is using a gallon less per hour now than he was.(We are talking heavy pulling) So due the math on how much he "saved" by not changing his filters earlier.
