Anyone ever tried to clean out a shallow well? I have one in my yard that I know had water in it 15-20 years ago but it is now silted in because the casing was broken off just below the ground level and it has slowly filled in, it"s 11 feet deep now and dry. Casing is clay pipe so I figure it"s pretty old and was here when the first house was built here, first map of the area shows a house in 1870. I have the upper part of the casing and can probably glue or cement it on ok but I would like to try to get it working and use it to water the lawn if possible, if not I"ll probably just cap it off. Guess my question is what do I do? I was thinking of a dirty water pump in the well, like the kind you get at harbor freight, and trying to break the silt up with a pipe attached to a water hose and just shoving it down the well and letting the pump pump it out. Any ideas, suggestions?
