Olds grill guard
grandpa Love
I think he should start a side business! Looks great.
The round bar is the same diameter as a Cat 1 3 point pin and solid rod. The square parts are 1/4 inch thick square tube the same size that fits the belly square implement mount. The grill part is guess what?? Grandpa Loves wife probably messes with that often. I made this so as to protect the tie rod which with out it can get bent pretty easy. As it is one of them on this cub is bent a little bit
I did try to send you more pictures of how it is mounted Kevin but due to the weather my phone would not send them out. I have to go get a Cat scan tomorrow and when I am out doing that I'll send them to you
It runs pretty good but does not have a lot of throttle travel so may have to try to figure out that but so far that has not caused any problems. Still have to use a lawn mower gas tank due to the tank being so bad
Maybe loves Cubs n stuff and olds grille and brush guard could start a joint venture ? I see a new website coming . Grille guard and grille look nice
Thank you. This is not the first brush guard I have made for a Cub but it is the first that I took pictures of. I have also made them for many other tractors like a IH 300U
I've worked to many types of jobs over my life time. I was one who tended to get bored with a job so I would move on if and when I got laid off. At one time I could tig weld a beer can so it could hold a liquid but that was years ago. I cannot draw a picture to save my life but if I can see it in my mind and it is metal I can probably make it unless it has to be something like a crankshaft
