olds pickup update
Nope haven't even driven it in days to afraid it will leave me sitting on the side of the road I I don't walk well any more. Guess I need to see if the Honda 360 will run and then load it up in the back and take my chances.
Have only heard pieces of the saga of old's pickup. Are you sure the hoses on the fuel lines are good? Had a simular problem one time. After two fuel pumps and being stranded in a parking lot with no one around, I finally figured out the hoses on the return side were rotted thus allowing the fuel pump to pump air and not fuel sometimes.
Well this one is an in tank pump so I know it gets the fuel to the injector system. The return line if bad would or should only dump fuel on the ground unless if course it is plugged up and don't know how it would act if it was plugged up
