oliver 1600 generator
John Cole
I put a new volatage regulator on my Oliver 1600 and changed it from positive ground to negative. It work fine for about 2 months then the generator overheated. Should I have done something with the generator or is just old and needs replacing
Well just for fun did you polarize it when you changed to negative ground? Is the regulator you purchased for a negative ground system? Unless a gauge has been added did you ever check generator output? (both amps and volts). My fist thoughts are there was a problem somewhere in the field circuit that caused undue out put. Do the batteries take extra water? Is this a gas tractor? Did you change the polarity of the coil? Just asking. J.
Thanks for the response. It is a gas tractor Batteries are fine. I changed the coil and gauge and checked the amp output. Everything checked normal. Do you know if it is a big job to replace the generator with an alternator?
John - I replaced a burned-out generator with an alternator on my father in law's 1600 industrial (gas engine). I did it simply because of cost: A rebuilt alternator is $40; a generator rebuild + new regulator ran about $150.
The conversion - including wiring - was straightforward. Had to modify the mounting bracket a bit and install a new (longer) fan belt. By using a Delco internally regulated alternator I as able retain the "generator" warning light in the gage panel.
The 1600 has run a couple thousand hours since - the alternator has required no attention whatsoever.
Bob
I put the delco alternator with the internal regulator on and everything works but the amp light on the dash. Did you have to do something different? My alternator has two wires coming out of it The red one hooks up to the battery and the white one hooks up to a wire from the switch that is only hot when you turn the key on.
