oliver 1650 general information
Anonymous-0
just got a 1650 diesel oliver and am changing all filters and fluid. How much trans/hydraulic fluid is required?
Thank You
sandra
Not sure if I understand if you are wanting the two capacities or not. The hydraulic and transmission are seperate compartments. The hydraulic fluid will need to be pumped out. The transmission takes 80-90 gear oil and capacity, well get 2 five gallon pails as at the minute I am having memory fade.CApacity of the hydraulic unit is close to 5 gallon. Also your hydra-power or over under also uses different fulid which when new was type A transmission fluid. More tonight if no one else answers you. Also if the transmission oil looks bad and you have two drain plus you should see if the screen for the transmission lube pump is clean.
When changing the hydraulic filter, be sure to grease each end of the new filter so the gasket doesn't stick and roll over itself when turning the cover back on.
