Oliver 550 water pump
Moman225
Hi guys:
Excuse my ignorance, but I have a 1964 Oliver 550 backhoe. I tried to order a replacement water pump, but the ones available cut off with the first three numbers at 127. My serial number begins with 144. Any ideas?
Thanks in advance
You need to know the casting number on your present pump. I'm thinking there are three or four different possibilities.
I would order a rebuild kit for the pump you have. As was mentioned there were several different pumps and if your pump casting is good it should be good for many more years. Questions?
I had a similar problem with my 55, 770, and 1650 tractors--I just took it off and brought it in to the jobber, (auto parts store, ie carquest) and let them send IT OUT TO THEIR REBUILDER THEY GET THEIR PUMPS FORM.--THAT WAY THERE IS USUALLY A WARRANTY ATTACHED TO THE PUMP YOU GET BACK
Thanks guys. Appreciate the replies.
Don't you love working on old iron? That you acquire from folks? And don't know what all has been done to it? Bought the ole machine, and it would run hot. Determined no cracked block or head and no thermostat. I looked for my old water pump casting numbers, nothing that looked like what the sellers ask for, so I had ordered one a year ago, kind of shot in the dark and got a duplicate of what I had, but had to use my old backing plate. I installed it and still ran hot.The new pump would not circulate. When I got time to work on it again, I ordered a second replacement. And it came with a backing plate. The new plate has a half circle cut in it that allows the water to flow from the pump back into the block??? My old backing plate merely had a pinhole.
So this may be why I was running hot. I will find out soon enough.
