tommie
Hi guys, we picked up an Oliver 60 that was a puller with an engine in it we are trying to identify. The number on the data plate on the engine is 609833 and the head # is 180-402. The bore measures 3.625 and we can"t match that up with any other Olivers we have data on. The pistons are stamped standard. Does anyone have a clue what engine we have here? Also, is the head standard or LP? Thanks, Tommie
The number on the data plate is for an Oliver 60. However the bore is not. The casting number for a 60 head is: 160002. Your casting number is for a 180 Waukesha which would be like an Oliver 66. Somebody put a set of 3.625 sleeves and pistons in the engine. The 3.625 sleeves & pisons were used in the later 550/660 tractors. See what casting numbers you have by the starter and also if you have a 1L180 casting number with a sufix letter on the head.
Thanks, J. You confirmed about what we were thinking in that someone had re-sleeved the engine, but we oculdn't figure out how they got to the 3 5/8 standard pistons. The head only showed L-180 with no suffix. The casting number above the starter is 180220. You've been a huge help. Thank you so much.
