I asked ,he said it was a secret . Fair enough .Don’t know much about Oliver but I was talking to a guy that was building an engine for a 77 or a70. He had bought a 454 Chevy sleeve kit with pistons, had the Oliver block bored to accept the sleeves and then had rods made to mate the pistons to crank.
How it all turned out I don’t know but after all that you still got to figure out how to feed it enough gas and air to make it run. There’s probably somewhere between that and stock to get more power but the question you have to answer is: How big is your checkbook?
Darn Horn anyway!! LOL I got DQ awhile back this summer..Close enough to stock, no one will know the difference. The 4 MPH horn takes care of the additional power.
You should have known better than to speed. You just got caught.Darn Horn anyway!! LOL I got DQ awhile back this summer..
Don’t spend any money on your motor. To little. I have a buddy that pulls in the top cut classes with an Oliver. He has a 310 Diesel, He is competitive in the 4 mph classes on a National level. Think the motor came out of a 1855. It had a turbo on it originally. Took it off. But did raise the compression. There is a 320 also it is in air compressors, or generators. My son has a 426 out of a generator. (He doesn’t want to sell it). It will bolt in also, kind of. Best deal is to go to pulls and buy the winners tractor, cheaper that way,There was a guy , president of our local pulling club that had an Oliver super 88 it was punched quite a ways . He did nt tell me the his neighbor in the club did. So I’m not to say any numbers . But it was so good he won the Ohio state antique pulling tour ( sorry don’t know the name of it) he had the jacket to prove it. Don’t have his number any more , I will ask around at the Geauga county fair coming up in a few weeks where Dave is , and what that tractor was for you.
Meanwhile you probably get a verification answer beforehand .
Those 70s used a Continental engine. The only ones to use it. Most of the other Olivers used an Oliver Waukesha. Whole different animal.Justin Dodge from IA is the Oliver guy to talk to. He builds some pretty tough stuff.
Does he have much for parts? I’m headed down so road bore out sleeves put dodge pistons in. Just hoping my crank wont need to be ground and find pistons.Justin Dodge from IA is the Oliver guy to talk to. He builds some pretty tough stuff.
Sounds like same thing i will be trying to accomplish. How big did you go over?I am building a Hart-Parr 5 gear engine. Nothing too outrageous. Boring sleeves, Dodge truck pistons from flathead Dodge truck. Wrist pins are the same size. No Rod modifications needed. reground camshaft and some head work. A little carb work. Stock antique at 4 MPH.
That’s what I’m afraid of when i get my crank checked. I was also going to try and keep pistons stock as well.I am going with stock Dodge pistons. I am not sure how much my machinist is having to bore out the sleeves. As far as the crank goes, I had 3 and they were all undersize for standard bearings. We searched Hi and Low for a set of undersize bearings of any size. We never found a set. We sent the crank out and had it chrome plated with hard industrial chrome. It took 2 attempts to get enough to polish back to standard. I hope to get started back on it soon.
