Oliver 88 weight brackets
Slow burn
Putting weight brackets on Oliver 88, could some of you with Oliver's takes pics so can get some ideas of how everybody is mounting them. Both front, and belly brackets would be greatly appreciated.
I don't have front weight yet -- but have weights on the belly --- My Oliver has the holes to mount the cultivator. I just got a piece of pipe the right size - cut a weight bar in two, welded to the pipe --- put the weight back on the weight bars
I can change weights no problem --and if I want the whole bar out-- just slide it out. I think their are two bolts holes above the holes in the frame.
Example
