Oliver 880 Correct Paint
EUG560
Hello, I recently acquired an Oliver 880. It is a 1958 model year. I assumed it would be the Meadow Green and Clover White for paint colors, but stumbled onto a "Mist Green" in a thread on this forum.
Just curious on the correct shade.
Thank you
There was a good Oliver magazine article a while back about the mist greens and a serial number range was established, I thought they were all 1959.... here's an old (but I think reliable) bit of information:
The mist green range should be 73639 thru 73891. The starting point is easy--it is the start of the helical gear transmission. There were 252 serial numbers assigned but 249 built. I believe I read that only 4 were LP models, 70 some were diesels, & the rest were gas. I also read that they were all row crops.
I also found a later magazine article from Jul/Aug 2021 in my HPOCA magazine which confirmed the serial number range above, and said 213 had power booster, 6 had power booster drive creeper, and 30 had no power booster installed at the factory. Of the 249, 12 were LP, and non were built as high crops.
Thank you
Share your serial number plate with us. I'll get mine on here too , it's a 58' as well. GG Wes
