oliver 880 ser no. help
Ed Hodge
i think the tractor is a 1960??? could some one help me??
spec no. 48-0013
ser no. 74-955-873
motor no.
104305-A
190320-N
4201 what year is it ???
First of all three of those engine numbers are casting numbers. The engine serial number is on the other side. If the same tractor you asked about on the Power Booster you will need to remove the cover over the power booster and try to move the handle that engages it forward and see what moves or does not move. The second filter you talk about is the transmission filter. The steel line is one of those lines. More questions? J/
thanks J. for your help.
i was told my 880 has a revercr o troc trans are thay any good? and are the parts avalible and for the power booster??? im new to the 880 i will have lots of ???? thanks agen
You have a helical gear transmission. You can not have a reverse o torque and a power booster in the same tractor. 873 is the code for a rowcrop 880 with a helical transmission and power booster. Parts I don't know you need to check with Agco. I have not worked on this stuff for 30 plus years.
my 880 is a mut tractor built from lots of other 880's the tag is off a dif tractor i was told is it posible to have both power booster and the reverse o torque trans ???
The Reverse-O-Torque bolts between the engine and the front of the transmission. The Power booster bolts up in the same space. You can not have both at the same time in the same tractor. If that tag is not for that tractor how do you know the code is correct? Now is the tractor with the 2 filters you were talking about? Do you have a handle mouted to the hydraulic unit you use to engage and disengage the Power Booster?
I forgot to tell you a Reverse-O -torque transmission will not have reverse gears. Reverse is accomplished by using the reverse o torque. Got to go. J>
my 880 has a power booster. it works on the high side but not the low side what could it be??? every thing moves fine but no low
Sprag clutch, maybe the shaft and gear as well. Engine will need to come out. Not a big thing but may be a little expenseve.
