Yeah, I was debating on replacing the sprocket or not. Part of me wants to, but the other part doesn't want to shell out $400 for one. I've been trying to look for parts machines nearby, but not any close or parts are worse than what I already have. I might just use what I have, and get everything else to where im satisfied. Then slowly bigger purchases as I go. I should repack/reseal the hydraulic cylinders as well, but until its gushing an occasional drip isn't going to kill me. Thanks btw.Looks good. At lest one om my tracks adjusts with a spanner wrench. Shame about the torch and the otherwise good sprocket teeth. Sometimes you weld a new tooth ring on a old center. Enjoy, great machines.
Ericp, feel free to post pics on my thread. I dont mind. Honestly I feel like there isn't enough pictures and how to on these machines on the net because they are so old. Not to mention the manuals are not that great photo wise. Blurry images and what not.Looks good. At lest one om my tracks adjusts with a spanner wrench. Shame about the torch and the otherwise good sprocket teeth. Sometimes you weld a new tooth ring on a old center. Enjoy, great machines.
Got my ammeter. I have some 4 gauge that is long enough to go from alternator to dash. I ordered some terminal ends. Old paper recommends 6 gauge, but ive got 4 left over from another project, and its red.Your call, regarding wire. That said- earth to starter is an excellent way. I think I put mine to a rear head bolt last head pull. Just go O or double O and send it. Ain't no rule you can't add a stubby 8 or 10 gauge to dash pannel, et cetera.
Output on alternator was 63amp, single wire. Re-running 4 gauge from alternator to 60amp ammeter, then rerunning 4 gauge to switch i believe it was on. Per instruction paper it called for 6 gauge. I figured 4 should be fine and handle any normal output. Should I install an inline fuse? Also I was thinking of wiring the light for ammeter on the input side of ammeter as an indicator, if the light is working alternator is working fine. Also it would be pulling a draw then.Good progress. 2 un-solicited tips: YOUR Fight. First, I also use the orig Oliver Ammeter, but if converted to an alternator, it may peg. #2 sounds sissy, so you may ignore. These were not equipped with fuse links for the simple, but now expensive electrical systems. A length of #10 fuse Link adds piece-O-mind, especially if your wife, buddy, or kid gets a hold of it. Any auto parts store can supply as "state of art" about 1970. Cheaper by 10' roll if you also have lots of pre 1980 tractors and pre '71 cars. EDIT, disregard part since looks like you bought 60A range meter.
