560Dennis
560Dennis
I think out of the whole experience, I would say I am becoming very familiar with this machine.
It wasn't new, it was an ebay new old stock. Seller even verified it worked with picture before I purchased.New ammeter didn't come with a bracket? The ones I get do; I don't trust gauges to physically be the same, seen too many variations. Needle going the wrong way is an easy fix, the wires just need to swap the posts they are on.
I agree, Ive used this site with past posts. Some of them even posted 20 years ago or more. I figured if I can contribute a sliver of photos, or methods, it will help the next person. Knowledge is built with time. Im happy this little crawler is a project to an extent, because it builds a foundation of me understanding what I have, and how it operates. With this time of year, Im really wishing I had a garage thoughYour original post said, I'm no mechanic!! You were not before, you are now. I believe I first started following threads and looking for knowledge on this web site 20 years or so ago. I was'nt a mechanic either, but with good people sharing information from this site, I have painted and tore down and repaired tractor engines transmissions and hydraulic systems carburators etc. Ofcourse many of the ones who shared their knowledge have passed on so it falls to those here today to share our knowledge and expertise at repairing and fixing. Congratulations on your project progress. I enjoyed the ride along....gobble
Or A then B from this picture. I will upload later. Pictures aren't uploading.
Wow, still can't upload pictures, well this tread will be boring. Today the OC46 started on its own without an IV. I replaced the wires from starter switch to starter, and negative battery terminal to ground at oil dip stick. I used harbor freight 2/0 solar cables 3' (had a 15% coupon), purchased a marine battery terminal end from autozone to bolt onto cable end.
Usually I have to pull a vehicle down to give it a little more juice, not this time. She cranked over like a dream. It did however rake some time for the pump to get fuel to carburetor since I ran it dry, but once gas got there it fired.
I also built a new cable for the ampmeter to starter switch and switched the terminals. Ampmeter was charging in the positive around 30, then settled down.
Ill add pictures when I can.
That 4 gauge or even 6 is way overkill. In most alternator installs on old tractors with 60 to 100 amp alternator a 10 gauge wire is very adequate. Especially if you are running one battery the max charge rate is rarely seen for any length of time short of charging up a dead battery after the machine has been jump started. Well too late already done.Got my ammeter. I have some 4 gauge that is long enough to go from alternator to dash. I ordered some terminal ends. Old paper recommends 6 gauge, but ive got 4 left over from another project, and its red.
I actually had a good bit of the 4 gauge left over from a solar install I did. I always end up hoarding extras of stuff. Probably next week or this weekend I'm going to open the final drive up on the right side. It will be interesting since I know they cut on that drive sprocket. I will post pictures of my findings. We've been fighting the bug the last 2 weeks in the household.That 4 gauge or even 6 is way overkill. In most alternator installs on old tractors with 60 to 100 amp alternator a 10 gauge wire is very adequate. Especially if you are running one battery the max charge rate is rarely seen for any length of time short of charging up a dead battery after the machine has been jump started. Well too late already done.
As Tom posted above, if you didn’t claim to be a mechanic before you qualify now. Happy Holidays!
