magnumpowers
Hello Everyone. I'm new to the BB and have some questions regarding rebuilding my Super 55 Diesel engine. Mine being very old, lots of blow-by is in need of some engine work. I see there are 3-1/2", 3-5/8" and 3-3/4" bore kits. I assume if I up the sleeve size the block needs to be bored to accept the larger sleeves. Is that correct? I am not sure if any engine machine shop can do the job without screwing up my block so that has me a bit concerned. Please advise on this. Also the super 55 only has 15:1 compression and I am wondering if larger pistons will help starting in cold weather being that would increase compression and heat? And also if I go with 3-3/4" pistons will I see more power or would the injection pump need to be recalibrated? And can these old American Bosch pumps be re-calibrated?
Thanks Much,
Charles
Thanks Much,
Charles
